jotacorsa
- between Santa Fe and Taos
Steve, the 120s use a larger, higher volume, oil pump. I suspect the smaller holes act as flow restrictors and may inhibit proper flow amount with the smaller, original, oil pump.
Schurminater said:Hi Scott/Piet,
thank you for your input,Its a 180 series 1 engine (1980) obviously i don't want to create an issue by leaving them at the wrong size.
Steve
