Hi All
On the triples, how many designs of cam pillar mountings were employed?
I've posted two types.
The earlier type looks like the pillars were free to self centre (once the cam is installed).
The latter employs a shoulder, does this shoulder conform to the shoulder on the billet cam pillars. Ie is the pillar locked in place or is it still free to self Centre? ( I think locked because they are often seen chewed up but I don't have mine to measure)
Was the later system more effective, ie with the cams positively located?
Finally, if you still follow, as its a weak spot for the small area that the pillars pulls down onto the head, should/ could the step also be used to support the pillar, ie some careful milling of the head, to match the pillar step.
Many thanks.
Many thanks.
