beauchemin
- Victoria, British Columbia
Does the camchain drive sprocket (on the crank) ever wear out? Mine has some grooves on some of the teeth.
Paul Marx said:It would be nice to put a window in the crankcase to watch that sprocket just like bevel drives
beauchemin said:Does the camchain drive sprocket (on the crank) ever wear out? Mine has some grooves on some of the teeth.
mcnicol said:Where would you put a window? When the chains's in place the only way you can see the sprocket at all is from directly above, with the head and barrels off. I guess you could use a fibre-optic snake probe with a transducer on the end of it so you could hook it up to a video display. Might look a bit out of place on our Dark Ages beasts, though.
Ken
beauchemin said:Rob, nice collection of photos! What happened to blow the hole above the transmisson?
Perspex cases - working on the moulds as I write ...Grant said:Quite a few folk, me included, managed to put a window in their crankcases, too easily... :'(
Robjota said:Ken Sorry, was being facetious. When conrods snap they put windows in the crankcase. Here's one done with a gear wheel also.
Rob
sfcpiet said:Rob,
Do you happen to know the mileage of that offending gear? Was the gearbox checked prior to thefailuremishap?
I find a lot of extremely worn 4th gear bushes and tend to think the failures are not due to weaknesses within the gear itself but the gear teeth no longer meshing correctly due to excessive wear in the bush, allowing the teeth to "ride" up on the layshaft gear and eventually blocking each other.
