camshaft repairs/re-grinding
TheWrongTrousers
South London
My 4c camshafts need some work on the lobes.
Can anyone recommend someone in the UK who can do this sort of thing properly ?
Joy engineering is a name that comes up a lot.
Thanks all.
Dellortoman said:
I think I read somewhere that Phil Irving used to profile cams with a hand file, then finish with fine emery paper. He must have had a good feel for what he was doing.
& an immense amount of free time!
That's quite OK if dealing with singles, multis are near to impossible to do in this style.
I've re-profiled my rust pitted cams after laser welding for my 100 Tourismo.  Thought I'd be able to grind the welds down with an oil stone, but with 70-odd HRC, you're going nowhere with an oil stone alone.  Ended up buying a power file, worked a treat.  Engine ran nice, too.
try David Newman camshafts in Farnborough, Kent.
Joy Engineering have been known( in the past) to take rather a long time to get the job done.
Anyone know who did the F1  180 cams for Keith, that was a can of worms. They had incompatibility issues with std Laverda cam buckets.
now I now who you are and where you are its just gotta be Newmans, they did regrinds for Mr.Todd at one time  I believe, Phil?
