In 2019, I approached Venhill with regard to their clutch cables for my Laverda.
I had gone through a number of them in a relatively short space of time. The final "standard" one lasting less than two weeks!
I tried their "Heavy Duty" ones which were, frankly, s**t. About the same cable thickness as my rear brake cable, it was impossible to release the clutch smoothly. As the tension was reduced, the cable whipped as it relaxed. Try using a normal clutch cable to operate the throttle and you'll get an idea of how useless they were, 630 chains come to mind.
I figured that Venhill deserved to be told. There's a convention, in England at least, of not giving feedback, eg.:
Sitting in a restaurant, at a table with others, faced with food that, somehow, is simultaneously both uncooked and burnt.
“This is dreadful!”
“ Whose idea was it to come here?”
“School dinners were ‘Haute cuisine’ compared to this!”
“Never coming here, again.”
The waiter approaches, “Is everything to your satisfaction?”
“Oh! Yes, lovely. We were just saying, weren’t we ...”
It’s the principal reason there are so many crap eateries in the UK.
If you don’t let them know that things are wrong, how are they supposed to fix them?
It was with that thought in mind, having recently seen some complaints on the interweb about others having suffered a few Venhill clutch cable failures, as I had myself, that I decided it was time to pop down to Dorking and have a word with them.
I could not have asked for better treatment.
Venhill have been in business for almost fifty years supplying cables and hydraulic lines for modern, classic and vintage motorbikes (on and off-road), quads, cars and karts, plus a wide range of domestic and industrial applications.
They’re not riding Laverdas on a regular basis though, so without Feedback how are they to know that a change to the way a nipple is fixed to the cable might be a retrograde step?
I took with me one of my thirty year old spare cables. One that had lasted long enough that the inner cable had started to fray which was why it had been retired to the ‘get you home’ spare.
When we examined it, in comparison, to my failed, old Venhill ones, there were two obvious differences: the trumpet nipple was considerably larger and longer which requires a suitable barrel nipple; it had been swaged, not soldered. Venhill have the equipment, on hand, to fix both ways and they kindly made me up a new cable, on the spot.
Because cables, like chains, have improved over the years the diameters required have reduced. This affects the way the cable lies and therefore the length for it to sit comfortably on the bike. Also since Venhill had built their cables based on an old, stretched one, the inner was longer than necessary, requiring a too long adjuster, at the bottom end, on which almost all the adjustment was used up.
On a later visit, some amendments were made and three cables were made up for me to test. Unfortunately they had not been able to source a suitable trumpet nipple which would replicate the OEM cable and reverted to a birdcaged and soldered top lever end.
Sadly, I must report that not one of them lasted even 5,000 miles, against Venhill's own target of 10,000 miles, as an acceptable service life. On one, they replaced the inner cable. That one lasted 1,400 miles!
Regrettably, I must conclude that they are not fit for purpose on my Laverda.
I currently have one of Andy Wagner's on the bike and I'll see how it fares. Though the availability of these, from Andy, may not be a long term solution given Andy's wish to retire.
I better order a couple of spare ones to see me through to the future.
