Oil pump gear is TDC. I tightened w/ Impact Wrench. Now I position oil pump drive but teeth would have to go into the oil pump gear & I can not freely move oil pump drive into position where dot is on top the arrows meet @ about 140 degress Oil drive side. Had to loosen it up again. Don't know what I am doing wrong. & then the timing mark on the oil pump drive is about 45 degress left of TDC. Must be right.
When taking apart
When taking apart
