I adjusted the Delorto square slides due to warmer weather. Now its a little longer to start and will die cold. When it gets to normal operating temp its fine. I only turned top screws slightly. Did not turn any mixture screws. Pulled plugs and a little carbon on one.
Also I am ready to put a case together. Should seals go on before top fits into place? Or should you put seals on after case is tightened? I've never done this before.
Then Mud Dovers got into a the header of an Sf that has the cross pipe on top. Ok Mud Dovers are an insect wasp in Texas that make nests out of mud. Surprised they got in. My garage is clean enough. Saw one nest at the top and got that out. But it is bugging me that they could have made one in the center x pipe. Ok I set the pipes top down and water blasted w/ garden hose. Water did not go out the top and came out the other side at a good pressure boogie. But it still bugs me...Was thinking of Petrol or Muratic acid. Ev
