Not quite Cam.
The crank is built up from 5 pieces, 3 pairs of webs, each with an integral main bearing journal, and a closing web at each end. The centre pair of webs has 2 mains and carries the cam drive gear and has bores for crank pins, the outer pairs have integral pins that press into the inner pair. Getting clearances right for the otherwise inaccessable roller mains is rather tricky, assembling these is a fiddly job. Apparently, many cranks are doomed the moment they are fitted! The outer races of the mains are very stable and shouldn't distort under the bearing caps. They are split by cracking, each pair of halves completely unique. The halves are held together with a wire ring in a circumferential groove until they are bolted up. The bearing caps that locate the split main bearing races have a tendency to shift these under the pressure of torqueing the caps, resulting in a step forming in the race. Doesn't take long for the crank to self destruct if run in this condition. I always wondered why so many of these sounded like a stone crusher at idle, quite clear now!
The rest of the crank drive and its mounting is impressive, as is the precision involved all round. Big end bearings are conventional, conrods are a work of art. Heads are another matter, not very much was changed since the engine was first drawn up in the '50s, very stone-age.
Engine is wonderfully smooth, as would be expected from a four. But it revs up totally differently than a Honda 4 for example, lots "looser", crank seems to have far less overall weight. Ride was a disappointment though, I reckon it couldn't hold a candle to a good SF2, let alone a SFC.
