thomas@hauge.net
- Gothenbourg, Sweden
Couple of weeks ago i fitted i kit on my Cagiva Grand Canyon and it only required some minor work making some distances in the lathe.
No I finally got around to fix the few annoying things on my RGS (rattling fairing, bad brakes, and harsh front end)
How ever, fitting the emulators is not as straight forward as on the Cagiva.
This is the damper rod from my RGS. The force from the spring is going directly to the top of the rod. To make the emulator work proper it has to seal against the piston (with the force from the spring), which only is in position with a small clip.
I made up new pistons, removed the valve in the top of the rod and I'm going to make proper washers to hold the piston in place so it can cope with the force from the spring/bike wight.
Is this the right (or one of them) way to go?
original damper rod
Damper rod with removed valve
New and old piston
Another solution is of course to make a new rod as well.
original damper rod
New and old piston
