pf1
- Portsmouth UK
Are the Breganze 750 and 1000 centre stand bushes the same?
Brass is for decoration, bronze for bearing surfaces but you would be best off with a hardened steel bush with grease.Brass is best?
Give us a hoy Vince, have lathe.Just to piggyback, do the Kawasaki side stands have bushes, mine is pretty flogged out and needs a rebush.
I wouldn't go with hardened steel bushes. It's a bugger to machine for a start. Also, the bush should be the part that wears, not the bore or the shaft (bolt). It's a simpler to replace a worn bush than reclaim a worn pivot bore in the stand. I reckon I'd use bronze (probably because I already have a big bar of bronze bush material lying around) but mild steel would be preferable to hardened steel.Brass is for decoration, bronze for bearing surfaces but you would be best off with a hardened steel bush with grease.
Simple enough welding job while you have the stand off. Then you can call your bike Bigfoot.It needs a bigger foot as well, I have no idea why side stands usually have a way too small a foot that sinks in and destabilises the bike, I guess it's good business to sell mirrors and blinkers after bikes fall over.
