hooksey
- Vic , Australia
Makes even more sense, with the value of our $ against the euro :
hooksey said:Makes even more sense, with the value of our $ against the euro :![]()
Matt888 said:Many thanks Ernesto & Stephane!
I must admit I'm a bit confused now:
Wirth 480mm
Wirth 500mm
Race Tech 425mm x 26mm 0.80kg
Race Tech 425mm x 26mm 0.85kg
3 different lengths, which one to choose?
I guess I could take out the original ones, measure them and replace by the same length?
Could anyone enlighten me on the differences to expect using different spring lenghts?
Mainly road usage, Ceriani fork with drum brakes (no discs).
Many thanks,
Matt
Paul H said:Matt, the length is not really that important - it is a secondary consideration. Initially you MUST worry about outside diameter of the spring. If you have standard road-going 35mm Cherries, the spring pocket in the top of the damper rod is diameter 23 and you may well have a stiffening sleeve inside the stanchion which is inside diameter of 25. You may find the race tech mentioned below do not even fit into your forks.
Vince said:What you want is 10 to 15mm of spring compression and that includes the fork cap being screw down. Measure fork sag when that happens. Sag dimensions should be approx 1/3 travel. None of this has anything to do with the spring rate, this bit is ride hight. You do need something big enough and solid enough between the spring top and the spacer. I use a thicker than usual washer and the spacer is usually thick-walled poly pipe
Piranha Brother 2 said:I understand that fitting a set of modern USD's to an SF0 or SF1 in orig state is absurd ... but just sayin' ....
It would look interesting with a huge drum brake on USD forks.helicopterjim said:Tell that to Chris Haerter or Adam Cecchini.
Jim
Tippie said:It would look interesting with a huge drum brake on USD forks.
