michipons
- Palma de Mallorca
Hi all!
Today I was rebuilding the Ceriani fork 38mm. (As a preceeding, the fork was the last 30 years on a garage with no movement) when I realized that one side was completely seized. I managed to open it and saw that the piston that I mark on the photo was not sliding at all, finally I removed it, but it doesn't slide in anymore, is like it would be a bit wider. The tube should be ok as the other's side piston slides perfectly.
Did anybody had similar experience? I never imagined that a piston fork could be seized, or even how. I thought may be would be a bit of oxide, but was well oiled so it wasn't the case, I sand paper it a bit but no improvement. As the part doesn't look too complicated, I am considering to make a new one with the turner or correct this one, is that a bad idea? or do you suggest something different? I didn't find this piston as spare part anywhere.
Regards and thanks for help,
Miguel.
Miguel.
