Diagram of the correct arrangement is on this forum somewhere since it's been discussed here before.Be careful Tom, I assembled mine in the wrong order after searching on here. Laverdamania has a drawing of the correct arrangement.
Pick an order, any order...
https://laverdaforum.com/threads/ceriani-damper-assembly.86845/
YesI am almost certain that the 35mm and 38mm disc brake damper rods are the same setup. The drum brake ones are very different.
Thank you Rob.Pick an order, any order...
