1200ts
- USA - Riverside CA
Trying to rebuild a set of 38mm Ceriani forks and the pistons have grown and are really stuck. Gentle bashing will not remove them. I have seen this before but never this bad. No signs of any corrosion and the oil was clean. Any other methods to remove them without destroying the damper rod?
Ceriani went cheap by choosing to use Zamak metal for the pistons which can grow over time if the zinc has any lead impurities in it. This was a problem up to the 1950's and if the zinc is properly refined is not supposed to happen. Whoever was making the pistons for Ceriani was buying very poor quality Zamak that was not inspected.
