michipons
- Palma de Mallorca
Dear all,
I have restored my old ceriani shock absorbers, I used the seals provided from Wolfang, re-chrome the springs, and repainted everything, they look great... 8)
According to laverdamania, the oil quantity is "full" and viscosity should be 20W.
I found only fork oil density 15, so I put this one. On the other hand regarding the amount of oil, teh term "full" is a bit relative, lets see if I can explain myself: when the shock is compressed, the rod slides into the bottle, thus reducing the available volume of the bottle, that means that if the bottle is full, there will be no "space" for the rod to slide in, so what I did was to put it full, then slowly compress the bar to the end, letting the extra oil to go out, then I closed the seal, on this way I am sure that the bottle has an amount of oil that allows the rod to go in.
Until now all good, but when I test them in the work bench, I have the impression that they rebound veeeery slowly, when I increase the preload of the spring, it rebounds a bit faster. May be with the weight of the bike and the preload, it improves, but I am not sure.... Any ideas or suggestions? I never tried ceriani absorbers before, but if I compare them to my koni in the le-mans or the Laverda 1000, those rebound much faster. After all the work I did, I would like to avoid buying a new pair of Ikon.
I was thinking to change the oil for a 10 or a 5, but that is a huge difference to what is recommended in Laverdamania...
Regards,
Miguel.
Regards,
Miguel.
