Ceriani Yokes
aerox_01
Hi,
I wonder if Laverda used the same top and lower yokes for the GT model and S model since the forks are a bit different.
regards
andreas
AfaIk, the yokes for the 35mm drum-brake forks are dimensionally identical throughout the entire 750 range.  Early ones were marked Arces, later Ceriani.  Only difference between GT and S/SF,etc forks are the lengthened sliders of the GT type to go with the sheet metal shrouds as opposed to the rubber gaiters or dust caps.
A few GTs were fitted with gaiters...
Varying length of metal shrouds as well incidently, otherwise, yokes would appear identical throughout the range but I wouldn't bet too much on it.
Ciao
didnt some 750's have a top yolk with cranked down (below the steering bearing) pich points for the stanchions?
Yes, Clem, but they had disc brakes.
That was the 35/38mm type, never used on either GT or S models.
Think so Phil.
Seen a 230mm 2LS Grimeca fitted in a 500, didn't look like it needed much persuasion, so the width would be about right.
