Chain lube
andychain said:
Tom that is part of the reason that many bike shops will not fit chains/sprockets. I offer a free fit service if peeps will come round and if the sprockets are not good I will send them away. I also know that the bike will go away with a properly fitted chain at the correct tension and at the same time will lecture the owner on lube and adjustment. Only ever, in nearly 40 years years, had problems with self fitted chains. I do of course refer to O ring, as the majority of non O ring chains are simpler.
Andy
Andy...It's nearly ten o'clock and all this talk of Lubrication and you downing a pint in your avabeeer has convinced me that I need a tincture of neck oil..So I'm off down the pup for a swift one..!!!
