AndyW
Morning all..
My Mirage isn't charging and probably hasn't been for a while. Given I may not have access to my usual retinue of Lav triple pushers on the way over to Bellingen I thought I'd best look into it before I set off...
12.35v across the battery with engine running (at all revs) and engine off. Wanted to check the regulator/rectifier before pulling the stator etc out: not sure how to check it so figured to do it by substitution with another unit, however, our local wreckers tell me it's unlikely to be the rectifier as they only kick in at about 13.5 or so volts to prevent over voltage, i.e. if the voltage strays towards the upper 14s and above then it's the regulator/rectifier unit. Is that what others have found?
Which wires do I check to see if it's the stator? Yellow?
thanks
AndyW
thanks
AndyW
