stevepm2011
- Cologne, Germany
While I have the Jota's carbs off, I decided to remove the stubs from the cylinder head and replace the o-rings.
This turned out to be a good decision!
The o-rings were flattened, but more disturbing were the casting flaws in one of the stubs - see picture.
I would guess that the flaw in the ring groove may well have bridged the o-ring sealing surface, leading to an air leak...
A potential cause of idle instability / one cylinder always a bit leaner than the others?
The porosity in the inner wall of the stub fortunately doesn't go all the way through.
So if you have a hard-to-trace carburetion fault, it may be worth taking the stubs off and having a look.
regards to all,
Steve
regards to all,
Steve
