TeddyG
- Portland Oregon
While waiting for parts to arrive so that I can re-start this 750 I recently bought, I tried a compression test manually w/o the engine running. I'm only seeing @ 50lbs each cylinder, so I'm either doing it wrong or there's engine trouble. One spark plug is screwed in tight and the compression gauge is seated into the other cylinder. I'm noticing that it's fairly easy to advance the motor in gear, using a torque wrench directly off the crank in a clockwise direction. The carb and choke cables are disconnected and waiting for new cables. I know compression tests are usually done on a running engine, so hopefully I'm overlooking something here, or I'll have a nice garage ornament. Thanks for any insights/ advice.
