lets not get confused here, and the American terminolodgy (or Canadian) may have created some variables,
take one float bowl off and dead centre you will see the main jet (it is screwed into the bottom of the emulsion tube) which will not have (much) effect until the throttle is 3/4's open, off centre is what we call in the UK the "pilot" jet this takes care of the fuel coming in on tickover or at teeny weeny (very weeny) throttle openings, not usually refered to as a starter jet in UK, because in PHF carbs THERE IS a starter jet. Both pilot and main jets can be changed from the outside, by removing the float bowls, (it is fiddly, you will lose something under the starter, so dont do it) but since you need to get a good look at the slides (are they all the same? are they scored?) take the bank of carbs off the bike and have a more thorough delv, you will also be able to see what needles you have (are they all the same? is the clip in the correct and same groove on all?) and have good general clean out, replace the float valves and their seats with ethanol proof type, this usually only get done when you have a sump full of petrol (eek).
the starter jet, well its not realy that, more like a "starter orifice" is external, but again fiddly to look at, where the choke cable enters the carb body (top) there is a pear shaped plate with a countersunk screw, remove this and the cable and it adjuster will be in free air, the plunger which seals the orifice at times when the choke is "off" wil be hanging on the cable at the end, the bottom of this brass plunger has a rubber insert, it should be hardly marked, it can be removed from the brass plunger and turned around, but they are cheap enough to buy and replace with new, so that is what I would do, with a magnifyer look down its bore hole and you will see the brass seat with raised edges, this is very unlikely to ever get blocked due to its size, but the "rim" needs to be in reasonable condition.
All of this prompts me to suggest that you remove the bank of carbs, put them in a box and send them to paddy, Be carefull when removing the bank if you have the type where they fit onto a male alloy spigot and are is0lated by a plastic sleeve in the throat of the carbs, DO NOT WIGGLE, pry them of in a very straight fashion, dont thump the bodies with anything, a squirt of WD40 wont hurt, and when you re-install post Paddy, be sure to add some lube to the male spigots to aid the removal the next time. I use 3 in 1. this does not apply if your carbs are the rubber mounted type, that is to say there are two jubillee clips to fix them to the manifolds.
