BobSol
- Coventry UK
Hi
You could use Moto Cross tubes, at least twice as thick.
Bob
Bob
What was the problem with the 90 degree valve?Vince said:I have had a couple of fast deflations, you go into a bend and the bike feels odd and you steady up slowly felling the second bend and by then I was pulling over. I had one of those external 90-degree tube valve extensions fitted to the rear constantly for years and then 2 weekend day rides it would break the seal and let the air out going from 40 psi to 10 in a couple of minutes. It took a while to work out why this was happening. It's now not fitted.
Vince said:I fitted it cause on rear spoked wheels its almost impossible to use Garage tyre inflaters as most have a long straight steel tip that won't fit the tyre valve. I now have a compressor at home with a connection that fits
Tippie said:Does air pressure hold things against the side of a receptacle, Cam?
DavidH said:Now I know why some people prefer to sit near or beside fat bastards on planes.
I prefer a bit more room myself, but it now makes sense after all those years wondering.
BobSol said:Inner tubes have been around since the invention of the pneumatic tyre and are, if correctly fitted, extremely reliable. The manufacturers recommend replacement at the same time as the tyre because friction between the tyre and the tube wears them thin. That's all the dust in there. Bob
Dellortoman said:Here's a practical application: If you have a window blow out in an aeroplane at 30,000 ft, just shove some fat bastard against it. The internal pressure will hold him against the hole and stop the cabin depressurising. And he doesn't even have to be adhesive.![]()
