Gareth99
As my Montjuic racing efforts show up the frailty of the engines and my mechanical competence, I now own 3 frames and 5 engines, and am going to build one good race bike and two road bikes over the winter.
As I disassemble all the engines to assess which bits to put in the race bike, I thought it may be useful to show the difference between a standard, and close ratio gearbox.
You can see on the mainshaft (with the clutch basket on it) that there is a very small gear at the far end of the shaft (it has 17 teeth). This is first gear. The close ratio gearbox first gear is much bigger at 21 teeth. You can just see the difference on the lay shaft which has 41 teeth as standard and 37 on the CR version.
Second gear (closest to the Clutch) is 22 teeth on the standard and 24 on the CR, and Third gear (second from the end away from the clutch basket) is 26 teeth standard, 27 CR. All others are the same.
