Hi All,
I am in the middle of installing new clutch plates in my 30 year old Jota, a job which is turning out to be bigger than Ben Hur. ??? My latest issue concerns the actuation rods and the hydraulic slave cylinder. While bleeding the hydraulic line after installing the plates the slave piston went past the point of no return and caused a large leak of fluid. After removing the cover I noticed there was not much of the rod sticking out. Does anyone have a measurement for how much should protrude?
I did inspect the other rod while the clutch was dismantled which looked fine. The ball bearing did not come out with it so I returned the rod and reassembled the everything. I hope that ball bearing is in there and in the right place. :
I'm going fishing.
Rocket
Rocket
