Clutch hub removal 1974 SF2
murphus
Removed the snap ring holding the clutch hub onto the input shaft on the 74 SF2 but it doesn't seem inclined to release. Give it a sharp rap to shock it loose from the splines? Always like knowing what other people do before I mung something up from ignorance.
can be a bit tight - a puller should remove it.  Or Try some heat - either a blowtorch or pouring hot water over it - do make sure no petrol about first1 - regards - Phil
Used a homemade puller.
A metal bar across the shaft's end with holes to 2 opposite
m6 threads in the hub.
Screwed in 2 m6 bolts with counternuts.
Tightened the counternuts equally against the bar
and that's it.
Ernesto
