Arnstein
- Kristiansund, Norway
Microsoft OneDrive
Pictures: Made this small bronze bush for to sit in the sleevegear before the oil seal. This is so the clutch pushrod cannot wander out of center "opening up" the oil seal letting dirt in which shortens the life of the needle bearing ( the ball in the piston seems a little out of center.) Had to polish the sleevegear shaft and make a bronze bush there too. Which, by the way, I know has been done by several.
On my other engine the shaft was so damaged it had to be turned down to 17mm and inner rings for needle barings pressed on and then a bronze bush in the gear.
