doublegarage
- California
I did some measuring of the Wolfgang hose adapter and the threaded hole in the slave - realised that the adapter wasn't reaching down to the flare/taper at the bottom of the hole, it jammed up in the thread before it reached there. No chance of sealing that crack/hole in the threads if the male and female tapers aren't mated.
I suppose this is why I've read all over the forum that you need a long fitting on the bottom of the clutch hose, so that it reaches down (~13mm) into the hole to mate with the hole's taper. Especially because the taper is in the 30mm cylinder insert, not in the cover metal, so the fitting reaches past the join between cover and insert. Sorry if this is obvious to 95% of people reading this but it's all dawned on me in the past coupla days.
It felt like the lower section of the hole wasn't tapped at all so I got a set of M10x1.0 taps, most usefully the bottoming tap - used that and the adapter then screwed in about 3mm/3 threads more. See below
I covered it in blue Loctite and let it harden for a day - tested it and it looks like it works now - no flexing of the cover and lever noticeably less effort - probably because it's not being used to bend 3mm of cast aluminium.
Remaining problems:
- The clutch is dragging pretty badly and the disengagement is right by the bar. With the slave now working properly this problem must be deeper in the clutch. I haven't ridden it on the road yet but it feels like I'm never going to find neutral
- As pictured above, there's a crack/hole in the clutch hose inlet so I don't think it's going to last forever - one day I'm going to need a proper fix from Keith or Clem.
-Richard
Remaining problems:
-Richard
