Clutch 'snatch'
a short post office run (maybe not up to full temperature) but not heartening ... not much change and a little judder on each start
will ride it for a bit and see if I get thrown off😬
There amazing, doesn't matter what you do the throttle, hard slow they just give a nice smooth takeoff.
I've observed over several clutch rebuilds that the pressure plate can be replaced in position in one of two ways.
The first being the position it came off relative to the splines, this is good.
If however it is placed 180 deg from original sticking on the splines can occur. This is easily checked with just a few springs in place.
Depress the clutch lever and let it out slowly, if the pressure plate return is notchy remove it and turn it around 180 deg, all should be well.
In the wrong position the clutch will partially engage and then click home when you're not expecting it.
Another symptom is the clutch slipping at high revs before clicking home fully, if you're lucky.
Delving further into my 1200 triple which has a few clutch issues.
It's a beast in traffic (as most might be) but having sorted the selector mechanism the remaining problem is a dangerous 'snatch' when leaving the lights in first. The clutch seems to slip a little (maybe) and then grab, unsettling the whole bike and very careful feathering of the clutch is needed to pull away. It might do this a few times before you get moving!
The clutch is now dismantled and is being checked out. No significant wear and the plates / springs are within spec. with no glazing and pretty clean. No clutch slip when under load or accelerating. The problem may be present at higher engine temps more so than when cold. Oil is Mobil V-Twin 20-50 (USA)
I'm considering drilling the basket(s) to alleviate heat and get better oil distribution (and try a different oil)
One concern is the amount of backlash present on the lay-shaft which is about 25 degrees. Could this be the source of it setting up a bounce / snatch?
Anyway .... please relate any comments / suggestions.
Is the primary chain correctly tensioned? If the primary chain is too slack, it can cause the symptoms you describe.
