L
lemonjelly
Guest
Bump started my old Zane once,successfully!
Dellortoman said:True enough, you won't spin the engine over as fast in a high gear. But some bikes won't bump start in a low gear. The problem being the torque multiplier effect as explained earlier. If a bike has too much compression, the torque required at the back wheel to turn the motor over will be more than the grip between road and tyre can provide. The wheel will just lock and skid, so you may need a higher gear.
Not so Rod. The reason there's less resistance to turning the wheel in a high gear is that the gear ratio is to your advantage. That means you're applying more torque to the engine (and clutch) than in a low gear.
If you don't believe me, do some arithmetic.
I can't remember the actual reduction ratios between engine and rear wheel, but exact numbers don't matter for the purposes of illustration.
Let's say 5:1 reduction in high gear (5,000 rpm at engine gives 1000 rpm at wheel)
The power output is the same (ignoring losses) so what you lose in speed you gain in torque. 100Nm torque at engine = 500Nm at rear wheel.
It also works the other way. Zfor example, applying 50Nm torque by hand to the rear wheel will apply 10Nm torque to the engine.
Now let's assume 10:1 reduction in low gear (5,000 rpm at engine gives 500 rpm at rear wheel)
So 100Nm at engine = 1000Nm at rear wheel. Which we know to be true from experience, it's easier to wheelstand in a lower gear.
However, applying the 10:1 ratio the other way. 50Nm at the rear wheel = 5Nm at the engine. Half of what you had in the higher gear.
The above argument applies equally to the clutch as it does to the engine because they are permanently coupled together via a non-variable reduction.
What all that boils down to is that if you want to use the rear wheel to un-stick the clutch (either by hand or by rolling along the road) get it into a high gear.
Alpino said:The same is true in the reverse. It is the practical reason that I wouldn?t try and break the adhesion at the clutch plates by turning the rear wheel in 5th. The engine would give way/turn more easily. Totally different if the engine has been mechanically locked.
A simple ? I stand corrected would suffice.
I agree it may be easy but you still have to drain the oil, possibly replace the gasket, realign the clutch plates, fix all the other stuff "while you're at it" so I would expect a littlePoffer said:Can't help thinking it would be a hell of a lot easier to pop the primary cover off for a clutch pull and clean. Fairly easy to do.
