Cold sweat moments
Because of their basic simplicity Laverdas lend themselves nicely to the attentions of the home mechanic and I guess a fair number of us take advantage of this.Most of us would think of ourselves as decent mechanics,well versed in the foibles of our particular machine and with a few tricks up our sleeves the so-called experts haven`t managed to fathom out yet.
However.......
as the years and miles go by there is always the possibility of the odd balls-up occuring,(afterall ,no-ones perfect).
One I`m going to admit to now concerns triple cam block bearings.
This was after 5 years/50,000 miles of ownership so there is no excuse but when I lifted the cam cover for a valve clearance check I found (to my horror) that at the last check (which involved a shim change obviously) I had failed to check that the No 3 cylinder exhaust cam block was seated squarely in it`s grooves,and was now staring back at me in this cock-eyed state.Averting my gaze to stare out of the window for a few seconds and then looking back again didn`t make any difference-it was still there.
Luckily despite having spent the last 6000 miles in this state damage wasn`t too bad and ten minutes with a couple of needle files reduced the visible damage by about 80%,and the block still clicked back into place and remained secure before being tightened down,which is the main thing I suppose,but I was still a little bit miffed(to put it mildly) that my previously pristine cylinder head had been sullied in this way,by my own lack of care and attention.
Steve Winterton once remarked in an interview that approx. half the heads he had seen had been damaged in this way,and even when Laverda increased the size of the cuttaways so even the most mechanically inept (cough) couldn`t fail to notice them,even then he still came across instances of damage.
I guess the lesson here is to take your time,don`t rush things and double check everything you do (even if you are working by torchlight in an unlit shed barely bigger than the bike itself-see,all these years later and still trying to make excuses).
Has anyone else had a similar `moment` which they`re prepared to admit to/managed to fix/kept quiet about and hoped no-one noticed ?
Spent a happy exciting weekend at the Festival of Speed racing Monty over 4 days.. pissed down heavy rain on Sunday so packed up and went home.
debrief in the shed revealed the cam chain joining link wire had broken.. 1/2 only still on the pins.. just see the result of that at the end of the straight..o_O
One other time my drive chain snapped at the start takeoff.. just one fast corner earlier.. :sneaky:
Ya Gotta Love Ya Racing
:cool:
A short time after I acquired my first triple, a Corsa spec RGS, I rode the bike up the A38 from Bristol to the Midlands for a job interview with Feridax. On the return journey, somewhere near Tewkesbury, a horrible rattle suddenly started and the bike ceased to proceed in a normal manner. A quick inspection at the side of the road failed to identify the issue. Once the bike and rider was rescued and returned to the workshop a removal of the fairing and tank revealed a plug had come out of the head. Unconvinced that could be the only issue, the head was lifted to inspect piston tops etc. With no obvious signs of any damage the engine was reassembled. A few months (and races) later, the head was inspected again, this time by a Laverda dealership who, among other things, remarked that the bike would probably have run a bit better if the valve timing had been set correctly. Oops! 🤭
P.S. I didn’t get the job either.....
My Gilera Saturno 2, as big singles do, got through drive chains and rear tyres at an alarming rate.
As I tend to wear things out past the limit or reasonable, I got home one day from work on the bike to find that the outer plate had disappeared from the spring ling in the chain. I wouldn't have got much further.
I also lost the gearbox sprocket on that bike on the move. Taught me all about Loctite that did.
I was arround 20 when the neighbor's nice daughter asked me if I could fix her Kawasaki Z 750 B.
The fault, a crankshaft broken in the middle, was quickly found.
When I got the spare parts I reassembled the engine in a night campaign. While cleaning the workshop in the morning, I found a spacer ring from the gearbox in the bowl with the used dark oil.
As young (and inexperienced) as I was back then, I would have continued to ride my own bike with this engine.
But since it was the bike of the neighbor's daughter, I gritted my teeth and disassembled the engine again and installed the spacer in the right place.
I swear to you - since that day I have been checking whether all parts for assembly are COMPLETELY available before assembling a motor.
Thomas aus LAU
I was doing a routine early season service a few decades ago on TOG, when on lifting the cam cover I found that the spring link was missing from the cam chain (YIKES!), well for years I had been saying that a new spring link every time is just a load of bollox, but there I was wishing that I had fitted new every time, which I now do, the exhaust was coming off anyway because the sump strainer was getting a clean but the cam pedestal was going to stay put, needless to say I removed it, and after quite a bit of "sweeping " with the fingers I retrieved the spring link, so very little harm done. the service was completed and Andy Chain supplied me with 20 spring links and a new one was fitted, but only the spring, the link and side plates from the existing get re-used here, as the wear just might make a tiny differrence, but who knows? several years later the motor was stripped bare and you could see where the casing had repeatedly pushed the side plate back on, doing a bit of minor damage, but it wouldnt have done that for very long before the side plate would have become dragged off, so a lucky escape.
.... that the spring link was missing from the cam chain (YIKES!),.....
Yes, I have also seen several times that the spring clip of the chain locks was no longer there (and the engine was still running).
Since then I have been always using the two individual clips that e.g. OCT sells. Never had that problem again.
Even if a clip breaks or is pushed open, the chain lock still holds securely thanks to the second clip.
Thomas aus LAU
Another almost unbelievable story that happened to one of us. But I prefer not to mention the name of the owner. 🤫
During an oil change on a beautiful Laverda, a friend came over for a short chat.
After a good cappuccino and a funny conversation together, the visitor drove home again.
Our Laverdisti then put on the helmet and started for a test drive with his beautiful Laverda.
He didn't get far ........
At home in the workshop there was still the unused new oil, the oil filter cover and a bowl with the old oil.
Conclusion:
Never interrupt an important work. If necessary, leave a note like e.g. "remove before flight".
Thomas aus LAU
Spring links have always worried me.Never had a cam chain link come loose but never liked the idea of one being fitted there even though it makes replacement of the chain a whole lot easier.
Used to fit replacement rear chains which came with spring connecting links and once travelling down the M5 from Bristol to Exeter (about 50-60 miles) when stopping for fuel at Exeter found the spring clip missing,but the side plate being an interference fit still there thankfully.
Thought it was just one of those things so fitted a replacement and the following weekend on the same trip exactly the same thing happened.
Tension and wheel alignment was as good as it was ever going to get so from then on only used soft rivet connectors for peace of mind.
The story about running with no oil is blood-curdling-A motorcycle journalist once arranged with a dealer (not sure if it was a dealer/importer,but post Slaters anyway) to take a 120 Jota for a test ride.Arrived at the dealer and was told the bike was waiting for him in the workshop.Went into the workshop,no-one there but the bike was there as promised so took it out,started it up and rode off.
Just a couple of minutes into the ride on a dual carriage way it became obvious something was very,very wrong.
Returned very slowly to the dealers where it turned out the mechanic preparing the bike for the test had drained the oil then gone off for his lunch break without telling anyone..........
Heard another story about something similar happening with another bike at a dealer where the bike was run without oil but as it seemed ok (!!!) was refilled with oil and returned to the showroom.
I remember a then ILOC chairman turning up at my place one Sunday evening with a triple on a breakdown van from Belgium due to lack of oil. We packed the bike on a trailer and my wife drove him to Calais to push the bike on to a ferry.
Realizing you are Hi-Siding into a sweeping Hi-Spd Corner, on the edge and running off asphalt with no where to go and you have to hit the handle bar OPPOSITE (Delibertly Hi-Siding opposite) , hang off and drag your knee and hit full throttle !
Practice it as it will save your life - Practice that form with every turn you take on a Breganzie = CAFE Riding Style.
Too many cold sweat moments on my 70 SF0 - Practice and practice more until it becomes Instinctive ;o)
Bought my drum brake triple from a dealer (Italmoto in Hannover, now the main Ducati dealer) in 1990, fitted with a Grimeca 4ls brake, was told the bike had been completely serviced, so I started thrashing it about for a couple of days. Had no previous experience with drum brake bikes. First time I came into a series of downhil fast straights with sharp corners at the end on a familiar road after about 5 corners I could suddenly pull the lever all the way to the handle bar without any brake action. The whole road had guardrail with a drop-off behind that, except at that exact momnt when I was shooting straigth ahead without brakes (of course I stepped on the gear lever to use the rear brake and got a false neutral for extra effect) there was a small gravel pathway leading off the main road to a field a bit further uphill. Didn't stay upright but managed only to break the 200mm lamp and the right side engine cover. Nowadays unforgivable offenses but got both new from Wolfgang back then. I could even ride home.... One second before or after I would have flung myself and the bike straight over the guardrail.
Laverda 1000.de - NEVER hit the rear brake when Hi-Siding all it does is stand your bike upright and you go straight ;o(
Bikes naturally Hi-Side, You have to take command when they do within a 1/2 second to save your life.
Similar thing happened to me . Went for blast to a mate of mine, just about 100ks to his place through lots of twisties for a bit of electrical work . Pulled up put bike on centre stand had a chat for a while pushed bike off stand to put in garage grabbed front brake heard phfft noise brake lever straight to the bar WTF. Braided brake line had worried itself by rubbing on a part of the front end, broke at right time I guess. Very lucky escape that one .
Most Harley Rider's don't even know WTF a Breganzie Rider is talking about Hi-Siding.
I owned 76 Harley AMF 850 Sporster and she defied Hi-Siding but I was also a owner of a Breganzie where you have to live with Hi-Siding and ride the bike accordingly.
If you want to Race a Breganzie you're always countering Hi-Siding - Just the Nature of the Beast ;o)
A mate in Perth lent me his SF motor while I was doing some crank work on mine - on the condition that I disassemble it and fit the 5th gear selector ring the right way around ... he'd made the classic mistake of fitting it with the flat facing west instead of east, where it engages with the dogs on thew 5th gear mainshaft output.
First oil change on my Skoda produced 8.5 litres of oil in a sump that takes less than 4! Dealer who'd sold and serviced it denied responsibility and said their 'technicians' always double checked each other's work!! Yeah, right. Was still under warranty so i contacted VAG and they sent me to a different dealer and ran drain and weigh twice and concluded it could only have been a double fill. Still, better than a no-fill!!
.....and concluded it could only have been a double fill. Still, better than a no-fill!!
Not allways. In the case of a diesel, however, this can also come to a runaway if the oil mist or the oil comes back into the intake tract through the engine ventilation. Then the motor turns independently far beyond the permissible speed.
The only way to stop the engine and save it is to stall it in very short time. See: runaway motor
Thomas aus LAU
I’ve come very close to doing the “start bike without oil” trick… the dipstick always waits on the seat now during oil changes.
Another one, and I hesitate to mention it in case it buggers up this thread, is when I was very young I rode off with the sidestand down (not Laverda). Crashed into curb on first left hander…
On the plus side, I learnt all about straightening forks 😁
Don't want to tell about an incident I had with a KZ1000 leaving the side stand down.
Not the 1st bike I laid down nor the 1st time I burnt legs on Hot Pipes; but, it HURT along with some road rash ;o)
