Hi
I had to remove the head of my 77 3 CL with 4/C cam as I need to fix one spark plug thread. Thats when I’ve found some things for which I would appreciate advice from all experienced Laverders. The attached picture shows:
A. Around all valves there’s a pearl necklace—like pattern. Does anyone have an idea of what that is?
B. The middle cylinder seem to run dry. The PO had all exhaust valves replaced because one of them was burned ( he doesn’t remember which but I assume it was the middle cylinder). This happened ten years ago but only less than 2000 kms ago. So, although the head was completely renovated at a professional workshop, I’m afraid the root cause was not resolved. So my question is, what is the normal main jet size on a 3CL with 4/C cams? Current size is #120 for all cylinders but when looking at other recommendations (e.g. DAM classic) it should be #145 for a 4/C. That’s a huge difference but could also explain why the valve was burnt previously.
Thanks
Axel
Thanks
Axel
