Excuse my ignorance! My old 3C (No 1399) and I are on a learning journey.
A compression test revealed results of 75, 60, and 45 psi. What should I expect? (Standard pistons)
Obviously something wrong so heads and barrels off to check piston tolerances. Ring gaps in the bore were around 0.65mm. Book says max should be 0.4mm. Oil ring was about 1.5mm. Max should be 0.5mm.
But then I read in the text of "the new green book" that rings in good condition will operate well with gaps of up to 0.9mm.
Do I need to go oversize?
My appreciation in advance for expected deluge of wisdom!
Fletch
Fletch
