thanks, Tippie and Keith
it is actually the two wire stator from the 81 Ducati 900 SS I am back working on, the thing doesn't charge, I replaced the regulator/rectifier with a known good Electrex unit I have, still no charge, then I tested the AC output between the 2 output wires and got 28 volts max at 4,000 rpm. All the wiring is good, and to be sure, I connected the r/r direct to the battery, bypassing the wiring harness completely.
what I expected to see was somewhere between a low of 75 volts AC and a high of about 90 volts AC, based on previous experience over the years with motorcyle electrickery... The Ducati manual is useless, says to take it to a Ducati dealer to test such a complicated item as a charging system......
the owner of the Ducati is reluctant to spend the money to have the stator rewound, which is about $200 around here, and won't spend the money for a stock Ducati stator at about $500. Odd with the existing stator (which I have removed) is that the two output wires are not soldered to the stator, they have some sort of mickey mouse clip setup, so as a further check I am going to solder heavier guage output wire and run a final output test, but I don't really expect to see any improvement in output, and if I don't, it is time for him to take the problem to someone else if he doesn't believe the stator doesn't need rewinding or replacing......
