Thanks. I'll have a look.I have the 1200 parts book. Item 9 on drawing 2, O ring on left side of lower crankcase half is listed as OR121. Putting that into the worlds best known search engine gives an O ring size 15.88mm x 2.62mm. I have used this to identify other O rings in the parts book, it does seem to work.
I double checked and very strangely, the O ring figures as you mention in the 1200 parts list, but not the other models.I have the 1200 parts book. Item 9 on drawing 2, O ring on left side of lower crankcase half is listed as OR121. Putting that into the worlds best known search engine gives an O ring size 15.88mm x 2.62mm. I have used this to identify other O rings in the parts book, it does seem to work.
OR 121Here is another example, OR 2021. These are the fork oil drain O rings. The numbers do not seem to relate to the size of the O ring.
OR121 indicates an interior diameter of 121mm.
There can be several thicknesses. For instance
I measured the recess in the case. It's about 1.2mm deep, so I imagine that a 2mm O ring would be perfect.
That would make it OR121X2
I beg to differ Steve.No, OR121 is a specification which includes internal diameter and cross section, in this case 15.88 x 2.62. There are a heap of different oring sizing standards, quick googling does not find where the OR designation comes from - likely an EU or IT standard I guess.
Here in the colonies here most oring shops will know the BS standard (often just called 'dash') and also standard metric sizes. The closest would be a BS114 (nominally 15.54 x 2.62), or I guess a 16x2.5 would work also. I expect in Europe any decent oring supplier will know what an OR121 is and can supply it.
I beg to differ S.No, OR121 is a specification which includes internal diameter and cross section, in this case 15.88 x 2.62. There are a heap of different oring sizing standards, quick googling does not find where the OR designation comes from - likely an EU or IT standard I guess.
Thanks Piet,15.88 x 2.62 is actually an imperial size, it equates exactly to 5/8" x 3/32". 16 x 2.6mm is pretty damn close and will work fine.
O-rings are pretty flexible in regard to sizing, pun not intended.
The OR standard as shown in the parts books seems to be either an old italian standard or a manufacturers code. In any case, the numbers bear no resemblance to the actual dimensions.
Paul, fitting a 12 x 2mm o-ring in this case is a sure failure waiting to happen. The correct 16mm o-ring will fit snugly in the cavity in the lower case.
shop.jlo-tech.fr
123 roulement is the place to go for seals, bearings, O rings, bushes, what have you..Another supplier of these O rings. A bit more expensive than the website listed above.![]()
Joint torique passage d'huile carter moteur Laverda 1000 et 1200 - Crankcases oil passage o-ring - JLO Tech
Joint torique passage d'huile carter moteur Laverda 1000 et 1200 - Crankcases oil passage o-ringshop.jlo-tech.fr
