cushion hub
johan
sweden
I have been driven with astralites wheel with astralite original "fixed" sprockets., But will now mount Laverda's cushionhub.
What I can see from the exploded views, green book, Laverda Paradise, etc., etc  is there  a distance between the ball bearings in the chain hub.
In my sprockethub is the ball bearings together with no distance in between and a clip at the end.
According to Keith is this  a SFC hub.
The question is what is the measure of the different spacers and bushings in an SFC wheels?
The most important is the distans between the cush hub and the cush plate.
Pictures or sketch would be gold.
Johan
I can't answer your question Johan but to be clear is it the measurements from an SFC 1000 rear cush drive hub you need? It's possible Lothar might know the answer.
At least 2 versions of the rear cush drive were used on the road bikes with cast wheels, they should interchange without problems.  Exception is the drive for the '76 750SFC which has a 20mm rear axle and therefore has a slightly different bearing set-up while using the same basic casting.
