This morning I put the cylinder in the oven & set the heat @ 300f. Cooked for 10 minutes. Got it out on the back porch set it up side down. Gave it a moderate kaiyay w. / wood several times. Pretty good grooves in the wood but the liner won't budge! Should I try 400f? For 20 minutes. Used Penetrating oil. Didn't stink up the kitchen like I thought it would. Liner I want in says TIP CCs Trattato. Measures the same. Inside on both will be bored.
Then I put the voltage regulator back on w/ rubber bushings. There is some tight play. I guess its Ok...or should it be loose?
