Thanks for the advice and info everyone. I should have been more clear on what I plan to do and that is de-glazing the cylinders. Fortunately we have several machine shops that can handle all the real honing and sizing, and if it is an issue I can have them de-glaze them too. What I don't know about is which types of cylinder finishes can be de-glazed and which ones will need the professionals to cut. Regular steel barrels seem straight forward but I have figured out that there is nothing I can do with the nikasil cylinders on my BMW's so they will need to go to a specialized machining/plating shop. In aircraft engines we have chromed and nitride-hardened along with regular steel, so are there more treated types of used besides nikasil that can't be de-glazed like a steel cylinder?
Along with this discussion of honing/de-glazing, what's the best way to assemble the pistons into the cylinders? When I did my R90S years ago the shop that dual proved the heads for me said to put them together dry, and then crank and go straight to 5K and hold it there until is smoothed out. I questioned them about really doing it dry and their answer was "put them together wet and we'll keep selling you rig sets since they won't seat". So I did as they said, engine sounded terrible, coughed, spit and then everything smoothed out. No oil loss, great compression, and a smooth ride afterwards so no additional ring sets were needed.
So should the cylinders go together wet on the Laverda's? I put them together wet the last time I did the engine and everything seemed to be fine but with all the knowledge you guys have I want to make sure that these will go back together and have great longevity.
Clay
