Dell'Orto boring
  • Thread starter Thread starter andyp
  • Start date Start date
I recognise that 1970s moustache :)
I'm to old to start all this special building again :-) Lets face it i cant even get the bog std 120 to run at the moment :)
What did you do - Change out pipes in you re-build?
Ensure your Enrichers  are seated, no air leaks in the Intake Manifold Tubes, floats set and floating - Clean Fuel Lines and Carb's of course and your static timing is on. I fyour Cam Timming is off for what erver reason - That's another matter.
It's gotta start as long as you got compression.
