gerty
- Fraserburgh
Hi guys anybody had their 3 cylinder dellorto carbs aqua blasted, if so have you had any issues with grit
ian
ian
Laverda SF said:How about Sonic Blasting with 99% Isopropyl Alcohol ?
Geeks blast their main boards and GPU's in this stuff to clean their electronics !![]()
Tippie said:Couldn't you measure how much it takes in instead of squirts out? Put a mark on fuel line held vertical with fuel filled to the line (not attached to the tank), and see how much to fill up to the mark again after the 20 squirts. I won't get into the discussion as to the necessity of those pumps, I have no experience of them on the 500s.
Dellortoman said:If you're mathematically challenged, I'll do it for you ...
Nat Magee said:Best way to adjust the acceleration pump is to disconnect them. You'll find the bike will run better.
