- Calgary, Alberta, Canada
Hi all
79 1200 with 4C cams, IIS ignition, back on 32 mm Dellortto's.
the bike has been running big bore collector and "Jota" mufflers. Exhaust needs to come off for some re conditioning, which will take a little while, especially if I send the Jota mufflers and the header pipes to be re chromed, if I can find anyone that still does that.
the carbs are presently at the bare castings stage on my bench, with the bodies being run one at a time through my small ultra sonic.
pilots 60, slides 60/2, needle jets AB 265, needles K1, clip set one notch below middle, and believe it or not, it has been running 145 mains for years with excellent results, clean plugs, pulls hard at wide open throttle.
I am thinking I may temporarily fit the Laverda factory 3 into 1 exhaust, any ideas on jetting changes as may be required? I have main jets in sizes up to about 160, 165, just have to dig them out of storage, or stay at 145's?
what will the 3 into 1 do to carb requirements? I am assuming it MAY flow more air through the motor, but maybe not, I have never played with a Laverda factory 3 into 1 before.....
