Don't think the valve had siezed. The wear pattern says inadequate valve clearance/insufficient lubrication over a lengthy period to me... the hardened surface wears off both the bucket and cam and the cam lobe starts hammering away. The top of the bucket becomes swaged and starts to jam in its' bore, until the jamming force is greater than the force exerted by the valve spring and sticks somewhere down low with the valve wide open. The valve then gets clouted and bent by the piston and no longer returns to its' closed position.
Whatever caused this to happen, it took longer than a happy little Sunday afternoon ride. :
