Disc screws
Paul Marx
France
Does it?
More to the point, can anybody give me the exact length of the screws securing the disc to carrier; 3C or SF2.
They don't figure in the parts lists.
Thanks
just get your vernier out and measure the depth, the disc and the washer, allow half a mill or a whole mill so as not to bottom, stainless bolts?????
I have used them for years, but now I am having my doubts, I torque them up correctly and lock them both with Loctite and Cor Dees (RIP) suplied lock washers, but on dismantling they havent seemed "tight" leading me to think that the stainless "gives" over time, the bolt heads didnt move, since they were trapped by the lockwashers,.
comments if qualified to do so, that rules out Hamish and Nickdav7 plus a lot of others.
ordered 6 x 14, 8.8 zinc steel.
I'll use a washer and Loctite.
Clem, I've used stainless screws to mount the disc carriers to the hub on my SF2 since 1992. No probs.
I can't measure it up Clem since the discs are mounted on the carrier and wheel and the wheel in the forks and I do not want to start again.
They were like that, just a bit long before the bike burnt but as you know centering the wheel is crucial and yesterday I shaved a bit of alloy off the rh slider whilst turning the wheel before getting it all right. The screws are a couple of mm too long.
getting the wheel bolted up to the left side fork leg is critical, (assumes callipers in front of forks) the right side fork leg "floats" on the spindle and is then clamped last of all, by the two pich bolts, do this with the right calliper unbolted and tied up away from its usual position.The two pinch bolts on the left fork left dont have much of a function at all, a bit of security if the spindle nut falls off perhaps (mine is always wired)
