Schurminater
- Surrey Hills
So while I am waiting for a valve shim to arrive,I need to get my head around the ignition system......as far as i can tell i will be running a standard 180 set up with a DMC 2 ignition that was already fitted to the bike.
I have picked up a few tips via the search button but would appreciate some guidance please.
I am running Beige coils and the ballast resisters are still fitted - I take it these should be removed ?
I should check the set up (advance) using curve 1? .......instructions for this please i presume I have to make a mark at 32 degrees on the flywheel,then strobe.
and once the system is set up on 1, I can then choose between curves?
The bike was found to be running on curve 5 having looked at the chart Curve 10 seems to be my preferred option,whats the general opinion on this?..........Ps i am not a fast rider........but that was before i brought a Jota
really appreciate your help and comments guys (thumbup)
Steve
Steve
