While possible the new opto is DOA, highly unlikely. One reason you buy several new parts, in case of faulty item.
Suggest a couple of test processes that you may decide to use, or not.
In a darkened ambient light, use your phone camera to look at the unshuttered opto gap ( or unmount the opto, while still connected ) the IR led will be visible on the camera as a white light. That will confirm IR LED is functioning. This works on past phones, have no experience with modern multicamera devices.
More fiddly would be to break out the photo transistor connections and put a meter across the Emitter and collector, slow rotate the motor/shutter and look for high volts and near zero low volts, that will confirm correct slotted opto function per se.
Take it that the mechanical dimension replacement opto does fit?
Electronics repair is a game of patience and process, can be unrewarding though when repaired, very rewarding. HTH j.
