The globe is earthed permanently. The switch circuit gives power to the brake light globe filament. If that circuit is earthed before the filament it will short out and blow the fuse (hopefully).It's a loop with a switch.
Problem is either switch or an unwanted earth.???
I don't remember seing a 750 with 4 functional fuses.I've been trying to find a wiring diagram for a 750 that has 4 fuses. There was nothing in the Library section. I see that Lee has one so they must exist! I found one online that I've now uploaded to the library https://laverdaforum.com/resources/sf3-wiring-diagram.144/history
It's not a particularly good copy, and it's in French. There may be better ones out there if anybody is keen to look.
Lee (Tippie), is there any chance of you uploading an image of your wiring diagram to the Library?
It's a bit hard to follow the wires on a monochrome diagram, but I think your fuses are from left to right: Park light; Lights/horn; Brake light; Indicators.
12V power for the brake light comes in at the top of fuse 3 and goes to the two switches in parallel (the two grey wires).
There would be a wire from the other side of each stop switch that goes to the brake light, and then to ground via the lamp filament. In reality, the two switch wires probably join together somewhere in the wiring harness and a single wire goes to the light. It must be somewhere in this bit of the wiring system that you're getting a spurious feed from a live wire. It's the only part of the brake light circuit that bypasses both brake switches. Follow the wires "downstream" of the brake light switches until you find something that doesn't look right. Maybe some insulation rubbed through against another spade connector or something.
The main fuse before the ignition switch will blow and stop the bike, from experience. It isn't easy to trace through that jumble. I have reduced the wires and passes through the terminal blocks heaps, I have now just one terminal block with a few unused in it. The brake light circuit is still as it came.Just as an aside, the ignition system appears to be un-fused according to the French wiring diagram. You can follow various coloured wires from the battery, via connectors to the ignition and kill switches, then to the coils and points without ever going through a fuse! The starter relay is likewise un-fused, so you should be able to pull all fuses and still start the bike. Is that really the case? (I don't have a 750 so I'm unable to try it).
No main fuse is shown in the diagram I've been looking at. It only shows the 4 in the fuse box.The main fuse before the ignition switch will blow and stop the bike
Yes, very simple. Something is providing power to the brake light filament via one of those grey wires with the connector. Disconnect both switches when you are trying to find it.Thank you all again- A friend more experienced w electrics is stopping by and I will pass on all your info and let you know when the problem is solved. In the meantime, here's a diagram of the wiring connected to the fuse block
My SF2 did when new, now only 2 fuses left..I don't remember seing a 750 with 4 functional fuses.
