DPO strikes again
Melle
when taking apart an engine do not use a screwdriver!
If it's a consolation, I have seen worse... :D
Nice finish, also soda blasted?
If the windage trays weren't removed for blasting, do check beneath them for lodged crap....
Hy Piet,
don`t worry; the trays where out. Finish is by www.wetblast.nl. Pressurised hot water with a chemical cleaner.
Anybody knows who "henk" is ? I guess he made the RGS head into a SFC/Corsa head in 0287 (head was made in `84). The engine number is 1277 so the head is probably not the one the engine left the factory with (would have been made in 82/83 then ?). Bike originates from Germany.
Regards, Melle
Hi, Melle.
It's "Schenk", not "Henk". He used to stamp
repaired components with the full name, not
just an abbreviation.
Was a German Laverda dealer in the 70s and 80s,
as far as I remember in Wiesbaden.
Ernesto
I recall some years ago that a UK firm advertised welding of fins etc back on to engines. After blasting the end result was almost imperceptible.
<can't recall who it was, maybe SRM.
Can anyone confirm or correct me?
Hi
    There is a man in Bilsthorpe, Nottinghamshire called WELDSPEK
    TEL 01623 870800. I have never heard a bad word said about him !
                                HOPE THIS HELPS YOU
                                        RUSS.
Ernesto said:
Hi, Melle.
Was a Laverda dealer in the 70s and 80s,
Ernesto
Thanks for the info Ernesto
regards, Melle
Motorrad Schenk still exists to this day.  They are now located in Idstein, close to Wiesbaden.  Not many Lavs these days, mostly jap crotch rockets and the odd Triumph and Ducati.
Remember downing more than just a few beers with Klaus Schenk in Breganze, 1983.  Nice bloke who also campaigned a 350 Manx in the then fledgling "classic" racing series.
The company is now run by his son, Michael(?), who took over after Klaus passed away.
occasionally the crankcases will  not part due to rust and corrosion on the plated studs which bolt them together, I have seen someone about to do serious damage to his cases because of this, here is what I did, it only happenned the once to me.
get out the arc (stick) welder, then make an adapter from a threaded rod extender like a hexagon nut but about 40mm long threaded all the way through, (a sleeve) you will need a 6mm one and an 8mm one easilly obtainalble form builders merchants for pennies, then with a short bit of rod in the extender, get a good earth for the lead on the welder, somehwre on the caes, and thengo to each stud in turn with your adapter, touch the eltrode holder on it and "blast" it with about 120/140amps for about 4 seconds, just to get the rod nice and hot, it might take a couple of pulses, and you might damage a stud (I didnt) do this to all of them if you dont know which stud is binding.
On reassembly just the lightest smear of copperslip will prevent future problems.
i've repaired heads in similar shape by using another fin from a donor head or cylinder.. if you match up the shape and thickness and the welding goes well once ground and blasted it's pretty much good as new..
