78jotadave
Very soon I am going to need to replace the fork seals, I have done this several times without problems. Now I am wondering what the obstacles might be to simply removing the front wheel and brake calipers, then loosening the allen bolt that holds the staunchion to the slider and pulling each slider down and off?
First things first remove both the drain screws from the lower part of slider pumping the forks to expediate fluid drainage then dropping the sliders as proposed above. Replace seals refit sliders wheel and brakes then remove top fo fork caps and refill.
What would be the drawbacks of using this approach? As opposed to removing the complete fork leg from the yokes/triple clamps. Comments and input very much appreciated, Dave
