Fitz
- Cheshire UK
Has anyone removed the speedo drive assembly / worm drive from an early SF1 with Laverda drum brakes, I assume its an inteference fit and will require a dremmell and chisel / heat to remove it from the hub, I will be fitting new bearings so I am not worried about them. I have just taken the front wheel out of my project bike and the parts are all beyond repair. The drive on the hub is badly damaged and the rest of the assembly is missing, I presume somebody in the past removed the worm gear after it failed and chewed up some other parts. I f anyone has both parts of the drive assembly please message me (UK) I need to crack on with this now the rest of the bike is nearly finished, just made room for it on pone the benches and the front end is next
