This tensioner bolt has snapped off in the the heavy rubber ? block.
1) Is this block a replacable part. Looks like I could bend back the tabs?
2) If I could replace could anyone recommend a suitable material ?
3) I,m sure its an original fitting but at least the wheel looks in good order ?
4) Could someone post a pic of how the part should look like. The GB does not have a clear pic
5) The double iwis chains have now been replaced which was maybe the problem along with running in the tensioner bolt
until it had nowhere to go
6) Other problem I,ve discovered on this bike is a very sloppy starter chain. Can you still get new ones ? Somebody suggested taking a link
out and fitting a clip etc but I reckon it would then be too short.
7) Any help/advice for novice appreciated
