Earth points
Laverda SF said:
sweetas: Suppose you going the tell us electrons don't flow from positive to negative and WTF is Current - Ever hear of the WheatStone Bridge. You opened your mouth and said nothing less then just about every member in this forum takes for granted regarding Automotive and Motorcycle electrics.
Suggest you concentrate on learning how to build a pivot electrical harness under constant vibration without it breaking.
Negative is the accepted Ground (What ever that is) - I recall my Dad's 55 Ford with a 6 volt battery with a Positive ground.
Stick around and you may learn something practicable over your theory.
Should not have did this ;o)
Use Vaseline
Yogi
Laverda SF said:
sweetas: Suppose you going the tell us electrons don't flow from positive to negative ...
Ron, Ron, Ron!
PLEASE try to be more careful!*
"Direct current or DC electricity is the continuous movement of electrons from negative to positive through a conducting material such as a metal wire ... <snip>"
Source (one among however many you may chose  :-*):
http://www.school-for-champions.com/science/dc.htm#.WWsrk7jRbGg
I know this may seem to be counter-intuitive.  But Sweetas is right.  (AND he made the point that he wasn't talking about polarity ...)
* And perhaps more polite, too?  ;)
Ventodue said:
Ron, Ron, Ron!
Agreed RON you f'd up, back to school for your son  :o :o :o
The frame is made of steel therefore why not take advantage of it to eliminate some of the wires. By attaching one from the battery terminal to the frame, you can then connect any electrical component simply by hooking up one side to supply and tother to the frame. Use a star washer and some corrode cure and bobs your uncle.
Oh and Yogi I am a bit worried about you too and your liberal use of Vaseline.. something you are not telling us hmm have you been taking hormones perhaps ???? you do seem quite partial to side stands if memory serves me correct  :D
Thanks Brett. By the way I had girl friend whom I called Brett the sweetas thing you ever saw but man when rowed had a foul mouth - LOL
When young (50 less), I looked at a race and never lost, armed with a 750 Breganzie SF.
Never enter a Race when you can't Win while shooting down Kawasaki 1000's with a 750 Breganzie.
Now I understand... when the Flux Capacitor shits itself, The Force turns to smoke and escapes!  Quite logical actually. :D
Yeah, it escapes and teams up with Lucas, the prince of darkness ;)
Don't forget you can do wheels with a SF slam shifting into 2nd from 3rd at 7800rpm going down hill with the wind behind you - LOL
So DO electrons flow from Positive to Negative or from Negative to Positive?
Just consider electrons are considered a Negative Charged Particle and repel from Negative Sources.
Lucas Price of Darkness Ignition Switches is a reality.
